Cannot evaluate field function Density
Like Tree3Likes
  • 1 Post By Blanco
  • 1 Post By Blanco
  • 1 Post By karahan
Old   July 21, 2017, 04:11
Default Cannot evaluate field function Density
karahan is on a distinguished road
Hello Everybody,
I am trying to simulate a relative simple incompressible flow field. Density is constant in the model physics and is defined. However, when I want to define a Report, in which a variable is dependent from the field function ${Density}, I receive an error in the beginning of the Simulation saying "Cannot evaluate field function Density".
I can overcome the Problem using a user-defined field function or a Report, where I insert the value of the constant density again.
Thank you for the answers.
karahan is offline   Reply With Quote
Old   July 21, 2017, 06:13
Blanco
Blanco is on a distinguished road
Which version are you using?
Maybe I'm missing something from your post, but if you define a report and want it to calculate, as an example, the surface average of density on a section plane, you just have to select density in the field function drop down menu, and it works as expected.
If you define a field function using density, e.g. ${Density}*${Pressure}, and you want to monitor its value, you have to create a report and refer to the name of your filed function (UserFieldFunction_1 or anything else you wrote). This also works as expected on my pc.
These, of course, after initialization of the simulation.
Can you further describe your problem?
karahan likes this.
Blanco is offline   Reply With Quote
Old   July 21, 2017, 07:03
The Version I am using is 12.02.010.
I am trying to calculate the volumetric flow rate (l/h) from the mass flow rate (kg/s). For that, I wrote in the Definition of the Report this expression: abs(${MassFlowAtPosition1})*3600*1000/${Density}. And the density is already defined in the physics continuum as constant integer (1000 kg/m3).
I am now using my own User-defined density function and it works well. But it shouldn't be necessary of course. I would be happy, if somebody has a solution. When not, at least this error is documented here.
thanks!
Old   July 21, 2017, 07:36
Blanco
thanks!
That's strange because if I use the same version it works for me:
abs(${MassFlow1Report})*1000*3600/${Density}
and it works even as
abs(${MassFlow1Report})*1000*3600/$Density
NOTE: in the field-function definition tab notes I get "floating point exception, invalid operation", stating that the function cannot be evaluated, but if I create a scalar scene or a report and I refer to the field function just created it works properly.
I've had a similar problem in the past, in another field function where there was a long-enough formula...I ended up in splitting the formula in single field-functions, and at the end the final field function was just a division of two: $num/$den. With this definition everything worked properly, even if formally there were no difference compared to a single formula...
karahan likes this.
Old   July 25, 2017, 06:01
I couldn't remove the issue but I came to the conclusion that it has something to do with writing the density in the denominator. If the density is in the nominator, there is no error. This might be a bug or something like that.
Thank you for your answer.
Blanco likes this.
Old   February 25, 2021, 11:20
Default Cannot evaluate field function Centroid
Prit K
Pkanugov is on a distinguished road
Hello everyone,
I am trying to create a variable density ( varying with height ) profile in a rectangular domain and the equation I'm using is:
0.2257*(pow($$Centroid[1],3))-0.4868*(pow($$Centroid[1],2))+0.06016*(pow($$Centroid[1],1))+1.301
I'm first generating a report using the expression and when I try to run the report ( after initialization ) I get an error saying:
Cannot evaluate field function Centroid.
Can someone please help me with this.
Thank you in advance.
Pkanugov is offline   Reply With Quote
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
