How to use Table(T,c) to define the material property?
Like Tree1Likes
  • 1 Post By me3840
Old   October 3, 2018, 03:03
Default How to use Table(T,c) to define the material property?
lee_2017 is on a distinguished road
Dear Members,
I am searching for advice to use the Table(T,c) function for material properties. I am using CCM+ v13.02.
Problem: I want to make a new Material Database and define the material properties with the Table(T,c) table but I get an error and there is no description in the manual about how has to be this table.
See structure here: Picture1.png
And if I do a right click on the "Test(liquid)" this window comes up, where some properties can be defined with Table(T,c):
The manual explains what is the Table(T,c) but doesn't describe how the input table has to be and which entries are requires. Has anyone an idea how the table has to be? I get an error when loading in the table, saying that there is an error due to the columns.
Thank you!
lee_2017 is offline   Reply With Quote
Old   October 4, 2018, 03:31
me3840 is on a distinguished road
It's been a while since I used the user-defined property tables like this, but IIRC...
Say you have a table defined for temperatures 300, 400, 500, 600 K
and pressures 1, 2 kPa
and you wanted to show densities at each point (I'll just say 1-8). Then the table would be formatted with all 8 points as:
T(K),Pressure(kPa),Density(kg/m^3)
300,1,1
400,1,2
500,1,3
600,1,4
300,2,5
400,2,6
500,2,7
600,2,8
This way each variable in the table is a single column. Be careful with the unit, if it is not recognized I believe star will treat the number as SI, but like I said it's been some time so please verify yourself that your table is being interpreted correctly.
OpenFOAM-2016 likes this.
me3840 is offline   Reply With Quote
Old   October 5, 2018, 10:23
Hello me3840,
thank you a lot for you help! It is working perfectly!
Regards
material properties, table(t.c)
Hydrogen storage by metal hydride longbk FLUENT 12 August 1, 2023 20:13
UDF to get the average temperature of a face and use it to define a property gdb Fluent UDF and Scheme Programming 19 November 3, 2022 03:11
How to delete or change material property in simFlow anraw OpenFOAM 1 August 30, 2016 07:09
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 13:32
problem of udf with material property france Fluent UDF and Scheme Programming 2 May 27, 2014 08:08
