January 12, 2018, 09:40 |
solution oscillating after few iterations
Saketh Bharadwaj
Rep Power: 8 |
I am trying to study flow around starship which has a complex geometry.
I am using k-epsilon model. "intensity and viscosity ratio" to initialise the turbulence model. The solution started to oscillate after 100 iterations. When I tried to refine the mesh i see an error "intersecting surfaces". I dont know what is the cause of the problem. I tried to implement few methods that were mentioned in the earlier posts...but nothing worked. Can someone help me to get through this..? thank you |
January 15, 2018, 10:14 |
Matt
This is a steady solution, right? I would suspect that there would be a lot of flow separation on this which will dictate a transient approach. Your residuals don't look bad considering this, but if you want to get 'smooth' residuals you will need to probably switch from RANS to URANS and select a time step small enough to resolve whatever behavior that is driving your residuals into oscillation.
March 11, 2018, 20:31 |
Steve
Rep Power: 8 |
Hello.
I think there's exist very small gap in fluid region.. when you saw 'intersecting surfaces' error. you should make more mesh in the small gap.. or modify geometry simply |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Foam::error::printStack after large bounding epsilon events | StoneCFD727 | OpenFOAM Running, Solving & CFD | 1 | January 1, 2018 17:04 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
