Sam Edwards
Rep Power: 0 ![]() |
Hi all,
I'm currently working on a project which is a simple angled hole in a plate (pre-swirl nozzle of sorts). Essentially my issue is that I don't have a value for the inlet velocity, only the pressure on one side of this plate and the pressure on the other side. 2 questions: * Does the inlet velocity matter? It will change as the iterations go on anyway * By setting the inlet face and outlet face at their pressures, does this represent the pressure of the large regions either side of the plate? Any advice on the most representative settings would be useful too, Thank you in advance, A newbie |
Rep Power: 24 ![]() |
Running a simulation with two pressure boundary conditions is perfectly acceptable, it's generally just more difficult to converge since it takes some time for the velocity to settle down.
So for your questions: No and yes. |
beginner, difference, nozzle, pre-swirl, pressure |
Pressure Inlet Boundary Conditions | Mr.Goodcat | FLUENT | 5 | June 20, 2019 01:47 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 13:04 |
Difference between total pressure, total pressure in Stn and in Rel frames | turbo5 | CFX | 6 | January 21, 2016 16:05 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
