How to obtain values of Energy, Continuity and X, Y, Z Momentum in StarCCM+ |
April 3, 2018, 12:02 |
Rep Power: 8 |
Hello everyone,
As the title suggests, I would like to obtain/access the values of Continuity, Energy and all the Momentums within the fluid domain in StarCCM+. Sort of like how you can use a predefined field function of Pressure Coefficient to obtain the values of Cp. Is there any method as to how to obtain such values since I could not find any predefined field function? Thanks |
April 4, 2018, 08:24 |
Sebastian Engel
Rep Power: 20 |
no, there aren't predefined functions the way you want them, except one, i guess. But they are easy to obtain. have a look at the Solver settings, such as the Coupled Solver. In its options you'll find one which is called "Temporary Storage Retained". Activate it. Then you'll have access to the Residuals and Gradiants and intermediate quantities. "Continuity" can be found under Mass Imbalance, while "Energy" is Total Enthalpy substracted by pressure/density (E = H - p/rho). However the Momentum always needs a reference point, right? To get the momentum of a certain surface, you'll find a momentum report. If you are looking for the local body forces you need to do a bit more. Have a look into the manual and look for equation 150ff for more information. Best regards, Sebastian |
April 4, 2018, 11:54 |
#3 | |
Rep Power: 8 |
Thank you for your quick response. I will check out the steps that you outlined and will get back to you if I am still stuck. Thanks alot! |
May 21, 2018, 17:42 |
#4 | |
Rep Power: 8 |
Thank you |
May 22, 2018, 06:34 |
Sebastian Engel
Rep Power: 20 |
i guess giving only the equation reference wasn't the best idea. Search for Theory > Numerical Flow Solution > Finite Volume Discretization > Coupled Flow Solver Then you'll get the underlying equations which you might have to integrate to get momentum on a specific entity. Best regards, Sebastian |
May 22, 2018, 23:35 |
#6 | |
Rep Power: 8 |
cfd, continuity, momentum, residuals, starccm+ |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
