April 25, 2018, 05:32 |
meshing in DNS
Songkai Yang
Rep Power: 8 |
Hallo Guys,
i am now working about my master thesis about the Simulation of the fluid in cylinderroom with Star CCM+. an easy question: if i choice DNS and laminar model in pysical continua, then need i to be meshing with prism layer or not? thanks |
April 30, 2018, 22:52 |
Lucky
Rep Power: 66 |
What is your core mesh type? Tets?
Prism layers are always a good idea, especially on tetrahedral-based meshes because it helps calculating the wall-normal and wall-parallel gradients. When you don't have prism layers, you often end up with velocity vectors that point into the wall. If you have a mesh that wraps nicely around the body then you don't explicitly need prism layers because you have these nice shaped cells already. |
May 3, 2018, 06:57 |
#3 | |
Songkai Yang
Rep Power: 8 |
thanks |
May 4, 2018, 10:57 |
Rep Power: 24 |
If you are doing DNS you may not need prisms depending on what the flow looks like. How much do you expect the kolmogorov scale to change in the domain?
I would avoid using tets for DNS, they're likely too diffusive. I would make a structured grid for that. Though I'm not really sure what discretization schemes are available that would be useful for DNS in STAR-CCM+...it would be best to use something not diffusive and high order, which is not really available. Unless in newer versions a DNS model exists? |
May 15, 2018, 07:40 |
#5 | |
Songkai Yang
Rep Power: 8 |
the flow is a cycle flow in the cylinder depending on the strokes. the kolmogorov scale need to be calculted depending on the inlet velocity? |
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 11:38 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
[ANSYS Meshing] Meshing strategy for External Flows | Hybrid | ANSYS Meshing & Geometry | 0 | January 24, 2012 14:27 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
