May 16, 2018, 15:24 |
Unable to Generate Scalar and Vector Scenes
RKE
Rep Power: 13 |
I tried to re-use and modify a Star-CCM+ simulation (probably created in an earlier version of the software). I removed the previously-existing scalar and vector scenes, and then made some iteration and convergence criteria modifications. I ran the simulation several times, making adjustments to the convergence criteria.
I now find that I am unable to create new scalar and vector scenes, although the simulation does run. The scenes are set-up exactly as they were in the old simulation. Can someone suggest what might be the problem? Thank you |
May 18, 2018, 05:05 |
Hendrik Weber
Rep Power: 8 |
Hi RKE,
does it give any error massage while creating the scenes?! If not what you see? Did you check you set the Representation to "Volume Mesh"? Cheers Hendrik |
