How to make a result from matlab as boundary conditions into star ccm+ |
May 23, 2018, 11:29 |
Songkai Yang
Rep Power: 8 |
Hi everyone,
i have a problem now. I made a calculation of the temperature, press and density in cylinder chamber according to crank angle by matlab. now i want to make these results as boundary conditions into star ccm+ in region. How should i do? Thanks everyone! songkai |
May 23, 2018, 14:47 |
Lucky
Rep Power: 66 |
You have a single temperature, pressure, at each crank angle or you have a field of data at each crank angle? For single quantities, you can save your data as a .csv and import the .csv into Star as a file table. Then you can reference this file table in the boundary condition. But you have to take care of the crank angle somehow. I don't know how you set up your simulation but usually it is a simulation in time so you provide a time column. Is it as simple as converting crank angle into time for your case?
May 23, 2018, 15:13 |
#3 | |
Songkai Yang
Rep Power: 8 |
i have a field of data, for each angle has a single value. i do not know that is belong to single value or a field. but i did not find how to save as .csv file. songkai |
May 23, 2018, 15:38 |
#4 | |
Songkai Yang
Rep Power: 8 |
i have known how to save as .csv file and next problem is as u said, how to convert crank angle into time? Thank u a lot! songkai |
May 24, 2018, 02:25 |
You must know the engine RPM. Calculate RPS from that. That many rounds in a second. From 1/RPS, you get the time require for single round. This time is for 360 degree crank angle. calculate time for 1 degree crank angle, use it as a time step.
May 24, 2018, 05:33 |
#6 | |
Songkai Yang
Rep Power: 8 |
I get it. then i write the converting equation in the description? |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 17:19 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
