June 5, 2018, 11:59 |
Mesh enlargement in the domain
fa
Rep Power: 12 |
Hello
I need to use a bigger domain for my model than I need because of the pressure outlet effect but I still need a very fine mesh. I would like to have three mesh values in the domain but I do not know how. my domain is 4mm * 4mm and I only need 1mm * 1mm area and another deep fine mesh in the bottom 20e-6 high * 1mm wide The best that I can do is to refine one area for about 25 % of the base size (any smaller then this value will corrupt the code for some reason in starccm+) I need about 1e-6 mesh size in the 1mm * 1mm and 25 % of that in the area 20e-6 high * 1mm wide the rest of the domain need to be very coursed because I do not need it and it will wast my computational time. If there is any way for me to have 3 values of mesh it will help a lot. by the way with this problem the mesh refinement XYZ table is useless because it also becomes corrupt and gives different values then specified. I think the problem it with the small cell size, starccm+ needs to adjust there code. |
June 6, 2018, 00:22 |
JOHN SHERJY SYRIAC
Rep Power: 8 |
you can refine different region in your domain using a volumetric control under the mesh continuum node
June 6, 2018, 06:05 |
fa
Rep Power: 12 |
[QUOTE=johnsherjy;694742]you can refine different region in your domain using a volumetric control under the mesh continuum
I am using it, but like I mentioned there is a problem with ghe code in star ccm+ when you try with small values. The limit with my values is no less than 25% of the base value. And that is not good |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
SnappyHexMesh... Domain boundaries are uneven | Blue8655 | OpenFOAM Pre-Processing | 0 | January 20, 2016 11:43 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
