Discussion flexible turbine rotates in water(FSI+6DOF) |
April 1, 2018, 05:05 |
Yongle Ding
Rep Power: 9 |
Hi,everyone
Problem I am working on a problem that a flexible turbine rotates in water. The softwares are starccm+ coupled with abaqus. Describe As the rotating motion of rigid body can be realized with the DFBI method. The question is how can I add the fluid structure interaction of deformation of the turbine blade in the this? Things Have been tried: I have already tried to use the morphing method in motion, however, the grid will be morphing to twist with rotating motion until the negative volume appears. The initial mesh is hereoriginal mesh.jpg After morphing with rotating the mesh twisted like this after morphing.jpg Thank you |
April 7, 2018, 01:11 |
Ping
Rep Power: 20 |
you should be rotating the system with a rotating motion and not morphing - it is for just the small deflections of the blades in this sort of model
i would use a cylindrical domain and rotate the whole mesh then do the fsi in stars fe solver use mrf first then maybe do actual rotation but this might not be needed not sure why you would need dfbi |
April 15, 2018, 10:07 |
#3 | |
Yongle Ding
Rep Power: 9 |
August 21, 2018, 11:41 |
Liwei Zhang
Rep Power: 8 |
Have you figure it out,i also want to add rotation and morph on fsi propeller simulation?
从我的 iPhone 发送,使用 CFD Online Forum |
Using 6dof for 3D turbine rotation | mg.mithun | Fluent UDF and Scheme Programming | 8 | July 24, 2018 00:53 |
Non-physical Results of Turbine - 6DOF | ram_call | FLUENT | 0 | February 2, 2018 07:49 |
Simulating a turbine rotatory with 6dof | jealor | Fluent UDF and Scheme Programming | 0 | October 23, 2016 06:40 |
CFD analysis on wind turbine rotor | Ken (Wind Turbine CFD Super Rookie) | Main CFD Forum | 45 | February 9, 2016 14:07 |
6dof for rotation of turbine: unable to fix the center | Havinh | Fluent UDF and Scheme Programming | 0 | August 5, 2015 05:35 |
