Geometry error
Like Tree2Likes
  • 1 Post By shaoyikai813
  • 1 Post By SoAero
Old   September 20, 2018, 00:23
Default Geometry error
yikai shao
shaoyikai813 is on a distinguished road
Hello everyone. Days ago I had mesh problems for both surface mesh and volume mesh like this picture shows:
Soon I realized this problem is from faulty geometry:
Sorry about these pictures, I’m not sure if you can see these lumps..
The original cad model has no problem at all, it is created in solidworks. But after I input into ccm problem starts, and CAD repair function inside ccm dosent pick the problem up.
I have tired inputting same model with different types of file. It actual made different! Also the “Tessellation Density “ option makes difference as well.
But no matter what I try, there is always some lumps by edges! What type of file do you guys use to input into ccm?
Thanks
shaoyikai813 is offline   Reply With Quote
Old   September 20, 2018, 02:40
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
I prefer STEP (.STP) file from CAD with default tessellation.
ashokac7 is offline   Reply With Quote
Old   September 20, 2018, 03:19
yikai shao
Just found , the “auto surface repair” inside “Repair surface” actually makes the geometry surface even more lumps! Have to be careful with this
Old   September 20, 2018, 10:11
Dominik
cfdominik is on a distinguished road
Sometimes the imported CAD geometry seems to have problems especially when it contains small roundings or things like that.
I had a geometry with small channels which looked crumpled in the 3D Modeller but after remeshing the surface all was fine.
So maybe it's just the representation in your case, too. Good luck!
cfdominik is offline   Reply With Quote
Old   September 21, 2018, 04:58
yikai shao
I have fixed the problem. It was because the Wrapper scale factor valve too big.
cfdominik likes this.
Old   September 25, 2018, 13:01
Owen
SoAero is on a distinguished road
The wrapper shouldn't be making a mess of that feature. Can you post a picture of the discretized input geometry?
I'm glad you were able to configure the wrapper to get what you wanted.
BRICE P. likes this.
SoAero is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
