Tumble calculation Ricardo Formula (Angular Moment Flux) |
November 20, 2018, 10:24 |
Andrea
Hello, I'm doing a steady flow simulation of a flow bench and I'm trying to calculate the Tumble Number with the Ricardo Formula
(8*Moment)/(Massflow*Bore*Isentropic_Velocity). I'm having some trouble in calculating the Moment in my simulation in order to compute the Tumble number. I have created a volume threshold in order to calculate the Moment in a specific region with a local Coordinate system (Tumble_cs) and I've calculated the angular momentum (Kg*m^2/s), with the following field function: ${Density}*${Volume}*($${Centroid}(@CoordinateSyst em("Tumble_cs"))[0]*$${Velocity}(@CoordinateSystem("Tumble_cs"))[1] -$${Centroid}(@CoordinateSystem("Tumble_cs"))[1]*$${Velocity}(@CoordinateSystem("Tumble_cs"))[0]) I've created a sum report of this field function computed in the threshold I was talking before. By far I know that it could be possible to obtain the Moment in this region if I could compute the Angular momentum flux (Kg*m^2/s^2 = Nm). Thanks in advance for the help Last edited by andreadepa; November 21, 2018 at 06:43. |
angular, flux, moment, ricardo, tumble |
Tumble calculation | pary07 | STAR-CCM+ | 8 | March 28, 2020 20:01 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Angular momentum flux through faceZone | askjak | OpenFOAM Programming & Development | 1 | March 5, 2010 14:42 |
flux formula & error distributions | student | Main CFD Forum | 1 | February 8, 2005 05:42 |
the calculation of convective flux | Hai-Wen Ge | Main CFD Forum | 14 | April 23, 2001 06:34 |
