April 17, 2019, 12:59 |
How to import data(xyz,time) to STAR-CCM+
Mohamed
Rep Power: 7 |
Hi All,
I would like to import the volume fraction data for each time step to STAR-CCM+ simulation through the (xyz,time) option. I'm having difficutly to fill-in correctly the excel file, becuase when i import my excel spreadsheet I won't be able to run the simulation. can you help me to share your experience of importing excel file that intended to provide different values at different time step ? appreciate if you can share with me the template of the excel spreadsheet to ensure that a specific volume fraction for each time-step. highly looking forward to your respond. |
April 17, 2019, 21:24 |
Steve
Rep Power: 8 |
Use csv format and make like this.. x y z time 1 1 1 0 2 2 2 1 3 3 3 2 and than.. you should match each coordinate and time in CCM+. x-coordinate -> x, y-coordinate->y, z-coordinate->z, time->t try again good luck |
April 18, 2019, 06:48 |
Mohamed
Rep Power: 7 |
Thanks for your respond.
I have tried doing what have you mentioned. but I found this error message: VolumeFractionArrayProfile:: Component-0Profile: profile method properties not set correctly: Non-existent column "null" what is the issue ? even i have tried to change the time-step but still the simulation cannot run and showing me every time this message I put 0 in all cells that is empty under all x, y, z columns. appreciate your assistance. |
April 21, 2019, 20:38 |
Steve
Rep Power: 8 |
Hi, Can you see your table contents after import?
You can check your report contents using right click on your table. Also, you should check your sum of volume fraction is 1. |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
