June 23, 2019, 10:22 |
Flow past a golf ball
Guido G
I am trying to model the flow past a golf ball and compare it to a round ball. My golf ball has a diameter of 42.6 mm, the depth of the dimple is 1 mm. I set a Re number of 150.000: Velocity= 53 m/s. Density = 1.204 kg/m3. Dynamic viscosity = 1.8205e-5 kg/m*s. D=0.0426 m. The solvers that I am using are: - Three dimensional - Segregated flow. - Constant density. - Turbulent: LES. - Implicit unsteady. I have uploaded an image of my mesh. I have run the simulations and the result I got is that drag force over the round ball is lower than the one over the ball with dimples and I should get the opposite result. Could you please comment on the settings I am using? Do you think that the mesh and the models I am using are proper for modelling this problem? Now I am using All y+ wall treatment. Should I use low y+ wall treatment? Thanks in advance. Guido. P.S.: I am trying to replicate the conditions used in this paper https://www.researchgate.net/publica...ning_Golf_Ball Last edited by guidolg; June 23, 2019 at 12:30. |
June 24, 2019, 09:40 |
Joern Beilke
Rep Power: 20 |
There are already many discussions about this topic on cfd online.
The picture doesn't show anything usefull :-( |
CFL3D,Incompressible flow,Laminar flow past a cylinder with Re=40 | ljnpu | Main CFD Forum | 1 | March 8, 2019 10:30 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
Ball valve flow in solidworks | nikesh | FloEFD, FloWorks & FloTHERM | 10 | December 10, 2013 08:40 |
Unsteady simulation of flow past wheel | Tom | FLUENT | 8 | January 18, 2006 10:54 |
simulating separated flow past the airfoil | Yusoff | CFX | 7 | January 16, 2001 19:19 |
