July 24, 2019, 05:01 |
Heat transfer coefficient
Rep Power: 7 |
I’m working on a heat sink I applied a heat source at the bottom, the fluid was over the heat sink. The issue here how can I get the heat transfer coefficient?. I used a surface average heat transfer coefficient but I don’t know where I can apply it?. Can someone please help understand how the heat transfer coefficient is calculated?.
July 25, 2019, 03:25 |
#2 | |
Little more information would be better. Also why do you want to calculate it? We calculate heat transfer coefficients for surface and fluid flowing over/around it. So you will not get any values when you try to plot it on cut section. You can get the values on your walls in your region. You will not get any values on inlets and outlets. Likewise we calculate HTC's on walls in CHT analysis. So that we can apply these values on solid. So it depends on your purpose to where you want to use it. Hope this helps. |
July 25, 2019, 08:15 |
Rep Power: 7 |
It is similar to the attached file I added the fluid domain but I don’t know how I can calculate the heat transfer coefficient of the heat sink?. I took the surface average (boundary heat flux) then I used an expression to divide it over the temperature difference but I got a wrong answer. What Q should I take i’m Kinda lost.
Heat transfer coefficient | Nadaaaa22 | STAR-CCM+ | 3 | July 28, 2019 16:50 |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 15:35 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
