October 11, 2019, 06:24 |
Contact region in StarCCM+
Gokkul Raj
Rep Power: 6 |
Hello Everyone
Currently I am working with Star CCM+. My geometry is a stepped pipe of three diameters in that one cylinder is a porous medium. When I imported the file (.stp) which has three part bodies, I get the contact regions. Will this contact region be a problem in the processing!! Thank you in advance!! |
October 11, 2019, 12:50 |
Matt
Rep Power: 17 |
The contacts are faces shared by two different domains or regions in your model. Interfaces can be created at part contacts so that information can be shared between regions. If you are modeling a porous region they are necessary and expected.
contact region, porous medium, starccm+, stepped pipe |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
[ANSYS Meshing] body of influence vs. contact region | Diger | ANSYS Meshing & Geometry | 5 | October 10, 2018 07:41 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Taking too much for run | Grimoli | OpenFOAM Running, Solving & CFD | 5 | November 26, 2013 20:07 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
