March 13, 2020, 11:01 |
how to calculate courant number
Emmanuel Sarpong
Rep Power: 6 |
i want to verify that my conditions for my simulation is correct. I am using the courant number equation deltaT/Deltax *v. What option in the mesh controls would you be able to tell the size of deltax?
March 19, 2020, 14:19 |
Rep Power: 24 |
That number will vary over the mesh. You need to look at the region you're interested in the mesh and determine what value to use.
Alternatively the convective courant number field function will compute the CFL on every cell independently. |
courant, delta time, mesh, time step |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
