April 8, 2020, 18:06 |
How to increase jvm heap?
Lucky
Rep Power: 66 |
I have the infamous java.lang.OutOfMemoryError when trying to export a plot containing a lot of monitors as a .csv.
Anybody know how to send the -Xmx option to the jvm when the Star server launches? |
April 8, 2020, 20:10 |
Lucky
Rep Power: 66 |
Solved.
pass -jvmargs -Xmx[#] as a command line argument when you launch Star-CCM. Also I learned Star abuses LD_PRELOAD and uses -Xmx768m ( max heap space of 768 MB). It ignores the system settings... which for my machine was already configured at 20 GB. =( |
November 25, 2021, 07:29 |
Will Crawford-Jones
Rep Power: 5 |
How would I do this when submitting in batch? I tried simply adding " -jvmargs -Xmx16G " to my batch script in the final line... " starccm+ -jvmargs -Xmx16G -np $SLURM_NTASKS -machinefile $NODEFILE -load FILENAME.sim -batch > OUTPUT " I have a large number of monitors like you and I keep getting the OOM error. The job consist of 80 million cells which should work out to require 200GB of RAM. I have tried up to 7 nodes each of which have usable RAM of 162GB. This works out as as over 1 TB of RAM. Hence, I don't think that this is the issue and think it's heap space. Any ideas? Thanks Will |
November 26, 2021, 09:38 |
Will Crawford-Jones
Rep Power: 5 |
OK, i've worked out that this was because I was initialising with pressure and velocity data taken from a steady simulation with the same mesh size (80 million cells). The CSV file was 2.5 GB and Star-CCM+ apparently couldn't handle it. I dont know the best way to initalise...
Temperature increase causes divergence in a chemical reaction system | nfurkan | FLUENT | 0 | June 27, 2018 07:22 |
Increase in flow rate decrease in Outlet pressure. | trovilb1 | System Analysis | 1 | December 5, 2017 07:22 |
Extremely Small Constant Increase of Heat Transfer Coefficient With Concentration | Shomaz ul Haq | CFX | 6 | July 9, 2017 08:06 |
Unexpected species increase in discontinuous phase | CeesH | Fluent Multiphase | 0 | August 6, 2014 05:41 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
