Import Table Data For a New Simulation in STAR CCM+
Old   May 20, 2020, 20:30
Default Import Table Data For a New Simulation in STAR CCM+
Raamses
Raamses is on a distinguished road
Hi! I am very new in Star CCM+ and I am developing a simulation of discrete element particles to generate a packed bed in a tubular geometry. I would like to know how data is imported from a table in Star Ccm + that contains the positions of the discrete particles in a new geometry (in my case the particles are spherical). I have already done the DEM simulation and I already have the table (XYZ Table) with the positions of the particles, but I do not know how to integrate them into a new simulation. I understand that it can be done by Java Macros, however I am really a beginner at Star Ccm +.
Greetings.
Raamses is offline   Reply With Quote
Old   May 26, 2020, 04:28
Ping
ping is on a distinguished road
you can use the table injector method using a table format as documented here in the help Simulating Physics > Multiphase Flow > Using the Lagrangian Multiphase Model > Working with Injectors > Using Injection Tables
however you say you have new geometry so you need to be pretty careful that you dont break any dem rules about injection as explained here Simulating Physics > Multiphase Flow > Using the Discrete Element Method > Defining Injectors in the Discrete Element Method
this is why it is generally better to use something like the random injector and let the particles settle properly under gravity
ping is offline   Reply With Quote
Old   May 28, 2020, 14:03
Default DEM particles as a new geometry part
Raamses
But right now my step is about include the dem particles (already have done the simulation of settle particles) into a new geometry, I mean. I need a new tubular geomety + the positions (XYZ) of the particles as a new part geometry. That is the issue I can't resolve.
Old   March 18, 2021, 20:15
André Luiz Moura Silva Moreira
Nabuchadresar is on a distinguished road
hello guys
I have the same problem. I did the DEM simulation and I need generate a mesh with the spheres with the position that them had on DEM.
Is it possible, with StarCCM+?
Nabuchadresar is offline   Reply With Quote
dem, packed bed
importing ducted fan from catia to star ccm Daniel4 STAR-CCM+ 0 November 3, 2014 09:34
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
How can i animate an unsteady simulation in Star ccm eleazar STAR-CCM+ 1 July 7, 2011 08:30
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
