September 17, 2020, 15:30 |
About the very fine mesh near the wall
Shi Lei
Dear all,
Recently, I am working on the 2D cycloidal propeller flows using the SST gamma-theta transition model. I put 65 and 75 layers near the wall respectively, resulting in the distance of the first layer to the wall is in order of 10e-8 and 10e-9m. Then, all the results change significantly. (1) the wall shear stress increases dramatically. (2) the velocity profiles on the one side of the foil are also changed. It seems that the mesh is quite fine and the results do not have so much change.Here I attached the two sets of near-wall meshes and corresponding velocity vectors. So, does anybody has some suggestions and comments about that? Very thanks. |
September 19, 2020, 02:02 |
Ping
Rep Power: 20 |
i assume your y+ in the recommended range for that model of 0.1 to 1 in both the mesh cases, but maybe not?
the first case shows a nice velocity gradient where the boundary layer has developed well, whereas the second looks like either early on in the flow field so the b.l. is still developing or the gamma-retheta model has caused the trip to turbulence to create a turbulent b.l. so maybe look upstream for some clues with relevant fields. |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
Wall treatment : Wall function vs Fine mesh | Gearb0x | OpenFOAM Running, Solving & CFD | 4 | January 26, 2010 16:09 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
