Particle Flow Rate injection specification using DEM |
March 1, 2021, 09:16 |
Sarah Scullion
Quite new to Star CCM+ - sorry if I have explained this badly. I am trying to inject particles into a pipe once the flow is fully developed. Is there a way to only inject a certain number of particles? I currently am using particle flow rate specification so that I can inject once the flow is fully developed. I have tried modifying the condition from the DEM conveyor tutorial "$Time < 0.5 ? 100 : 0" to be "$Time > 0.5 ? 1 : 0", although this is still too many particles - as it continuously injects them . Is there a way to modify it so that it only injects say 2 particles per injection point after a set amount of time? Or even only injects them between a certain time frame? Let me know if you need extra information. Any help would be greatly appreciated! Thanks |
March 3, 2021, 14:11 |
André Luiz Moura Silva Moreira
Rep Power: 11 |
Hi, you can choose type: "Random Injector"
>>"Condition node" >>> "Particle packing specification" and set "particles count" >> "Values node" >>> "Number of particle" and set the number of particles you desire. On this way you set the amount of particles you need. But the particles will appear randomly inside your pipe (if you set the pipe as input) StarCCM+ has some different types of injectors, you can play with them to solve you problem. In "injection point" you can choose >>"Condition node" >>> "Flow rate specification" and set "particles flow rate" >> "Values node" >>> "Particle flow rate" and set the number of particles (by second) you desire too. But here you choose how many particles will be injected per second. I hope I understand your problem. |
dem, injection duration, particle flow rate, star ccm+ |
Particle diameter and particle flow rate not as specified | CFD-HP | STAR-CCM+ | 0 | September 30, 2020 08:32 |
Exit Corrected Mass Flow Rate Mesh Sensitivity Study | s__s__s | CFX | 4 | July 20, 2016 11:46 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
Variable mass flow rate injection. | Eng_mech78 | FLUENT | 0 | April 4, 2011 11:49 |
liquid particle track and flow rate | Tim | FLUENT | 1 | November 28, 2001 21:41 |
