Spanwise Pressure Coefficient Distribution of Rotating Wind Turbine Blade
Old   March 16, 2021, 05:51
Default Spanwise Pressure Coefficient Distribution of Rotating Wind Turbine Blade
Niall Whelan
niall54321 is on a distinguished road
I'm currently working on a Star CCM+ model of the NREL Phase VI wind turbine for validating a VLM code.
I have everything complete and all reports and residuals converge well but I am trying to compare the pressure coefficient distribution at various span wise locations of the turbine blade from the CFD model to the experimental data. My problem is that the experimental data is normalised along the chord from zero to one and my CFD data is using [0 1 0] direction and as the leading edge of the blade isn't coincident with y=0 and the blade is twisted I am not able to properly compare the results.
How does one plot the pressure coefficient data against a direction that is from the leading edge to the trailing edge in Star CCM+ for a rotating twisted blade?
Thanks in advance!
Regards,
Niall
niall54321 is offline   Reply With Quote
Old   March 16, 2021, 08:40
Matt
fluid23 is on a distinguished road
This request is not totally clear. Are you asking how to plot cp distribution around the airfoil shapes at different spanwise stations along the rotor?'
You can create derived parts (probes/lines) that snap to a surface that are defined in a local coordinate system. The help material is very useful in this regard.
fluid23 is offline   Reply With Quote
Old   March 16, 2021, 08:45
Niall Whelan
Thanks for your reply!
Sorry if I am being unclear!
I have been successful in setting up the derived parts and the Cp plot however, when I plot the pressure distribution data in Star CCM+ the X-axis uses a vector direction of [0 1 0] which is not representative of a rotating twisted blade. I am looking to figure out how to set up the x axis of the x-y plot so that it is parallel with blade chord and that zero on the x-axis would align with the leading edge of the blade at a given span-wise location?
Hope this is clearer!
Thanks again!
Old   March 16, 2021, 12:38
Matt
Create a local coordinate system at each station that is aligned with the chord direction and centered at the leading edge. Then you can create field functions to define a normalized position (x/c, y/c, z/c) vector for each station that references the local coordinate system you created.
Old   March 16, 2021, 12:39
Matt
duplicate post deleted
nrel phase 6, postprocessing, pressure distribution, star ccm+, wind turbines
[BladeModeler] Geometry and Meshing for Failure Analysis of Wind turbine blade Wajeeh ANSYS Meshing & Geometry 0 December 30, 2020 05:17
Pressure Coefficient with a Minima of 0 on Compressor Airfoils in Cascade cdelorenzo CFX 6 August 22, 2019 06:36
AutoGrid - Meshing wind turbine blade Ko_Shine Fidelity CFD 4 December 20, 2018 11:27
Profile pressure distribution in wind turbine FJSJ FLUENT 0 September 7, 2013 08:26
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
