Displaying section of Part in Scene
Old   April 27, 2021, 08:37
Default Displaying section of Part in Scene
cwl
Chaotic Water
cwl is on a distinguished road
Hi everyone!
I have a question that might be lame or sound silly, but ...
Imagine we have (solid) parts (pipes, blades, tubes, shrouds .. whatever) that are used for extraction of the flow volume, and that volume is meshed afterwards and simulation run on that mesh. Good.
We surely can plot simulation results as anything anywhere inside the volume, but showing the (solid) parts makes it more representative.
Yet showing them might block (or cover) all the simulation results displayers.
One way - is to make (solid) parts transparent, but that does not always look good.
Another way - is to display them sliced, like in the attached image (stolen from the internet).
But:
- Displayer (surface) of a plane section (with Parts property set to solid parts) would show only contours of the intersection of the plane with surfaces of the part as the part does not have a volume mesh representation;
- Clip Planes .. just clip, they do not show (fill) the clip section (as it does in 3D-CAD tool);
So I wonder - how can a section of a Part be shown filled in a Scene?
PS The only dumb solution I can imagine is to mesh solid parts too .. but that is insane.
cwl is offline   Reply With Quote
Old   April 27, 2021, 10:55
Joern Beilke
JBeilke is on a distinguished road
Just duplicate the solid and cut it at this section.
JBeilke is offline   Reply With Quote
Old   April 27, 2021, 11:31
cwl
Chaotic Water
Thank you for your idea, I also had it in mind - but that is hardly an elegant solution.
Also - CAD model might be unavailable, so that would require subtract at the parts operation level .. too complicated for a simple thing.
I was hoping for a simple trick that I was missing.
Old   April 27, 2021, 15:40
Joern Beilke
You can load the geometry into the cad-module and simply cut it there. Nothing is easier than that.
Old   April 27, 2021, 21:38
cwl
Chaotic Water
Not that easy.
One might not have a solid body CAD model and thus geometry would be imported via Import Surface Mesh.
Which again can be done by subtracting some block at the parts operation level, - but that is a way too complicated solution for such a simple issue.
In general - that is a routine hand work, especially in case of running multiple simulations using Replace Part operation, and it should be done automatically.
Old   April 28, 2021, 02:18
Joern Beilke
You can write a little macro for this.
Old   April 28, 2021, 09:00
Lucky
That is true for an outline. Create a surface displayer and enable filled. And choose your favorite color for the filling.
Old   April 28, 2021, 09:26
cwl
Chaotic Water
That's the issue - it would display only contours even if filled is enabled (i.e. Surface is checked in Displayer properties) if part does not have a volume representation.
And that is kind of logical - since part without mesh is just a set of surfaces.
PS Setting Surface Displayer Representation to Latest Surface or Geometry expectedly does not help.
[swak4Foam] run-time function/expression evaluation at a part of a cross section silvan OpenFOAM Community Contributions 3 August 3, 2015 10:12
Importing ccm file - Creation of geometry part from boundary crevoise STAR-CCM+ 1 January 10, 2013 03:17
Modelled Part of Reynoldstresses in Channelflow LeFrog OpenFOAM Running, Solving & CFD 0 November 16, 2012 09:01
Links Section - Major Update! pete Site News & Announcements 0 February 6, 2012 07:51
[Other] cgnsToFoam problems with "QUAD_4" cells lentschi OpenFOAM Meshing & Mesh Conversion 1 March 9, 2011 04:49
