December 2, 2021, 22:24 |
Sweep Parameter Study
John
Trying to perform sweep parameter study before messing around with DOE and Optimization.
I have attached a document with the geometry and the steps I have taken. I have a jet impinging on a heated surface as indicated in the fluid volume image input to the study is mass flow, and the response is Nusselt Number vs Z (from the origin of the heated surface to the edge of it) I followed the siemens learning advantage tutorial: Advance analysis Not sure why there is no output for this. should be pretty straightforward. Any suggestions? |
#design_manager |
Parameter/Geometry sweep study in STAR-CCM+ | Seervan | STAR-CCM+ | 6 | November 1, 2017 22:06 |
[Workbench] odd problem of updating parameter study mesh | funkvps | ANSYS Meshing & Geometry | 0 | August 17, 2017 11:51 |
Results from parameter study | -mAx- | FloEFD, FloWorks & FloTHERM | 4 | March 4, 2015 04:18 |
Parametric study and time dependent parameter monitoring | Crustulu | FLUENT | 1 | April 12, 2013 05:54 |
Average of Expressions in Transient Run for Parameter Study | BigPapi34 | CFX | 1 | August 7, 2012 05:34 |
