Spurious minima for inlet Mach number distribution
Old   March 20, 2022, 21:32
Default Spurious minima for inlet Mach number distribution
mnws is on a distinguished road
Dear all,
Please see the image attached. I am simulating a 2D turbine passage with pulsating inlet conditions, using stagnation inlet condition. P0 and T0 pulsate with time, as seen in the graphs in the image. P and T are also periodic.
There is a problem with the inlet Mach number distribution. The orange curve in the image attached shows the correct inlet Mach number obtained by simulation (outlet conditions of a rotating detonating engine), you get the same distribution if you were to calculate it from isentropic relations.
I suspect that the spurious minima (seen in the blue curve) of the inlet Mach number could be due to reflection at the inlet. I'm not sure why the Mach number has this problem while the stagnation and static P and T are fine.
Thank you
mnws
mnws is offline   Reply With Quote
parallel run OpenFoam Srinath Reddy OpenFOAM Running, Solving & CFD 13 February 27, 2019 09:15
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 03:58
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 15:05
AMI interDyMFoam for mixer danny123 OpenFOAM Running, Solving & CFD 4 June 19, 2013 04:49
Mach number distribution Kumar Sanjeev Main CFD Forum 0 September 7, 2001 11:01
