March 24, 2022, 07:57 |
Different conditions, same results
Sam
Hi all,
Just looking for a little guidance here, quite new to STAR CCM+ so please bear with. I have changed initial conditions (velocities) on my analysis of a 2004 F1 front wing, and it has given out the same results (drag and downforce plots) as it did at other velocities, this has been tried at 100, 150, 175 and 200mph, all returning the same figures, but the first iteration starts much higher as the speed increases, before coming down and giving out the same figures as the previous simulations. Have I missed any settings or is there anything in particular that would cause this? I am also getting the same pressure, friction etc. readings no matter the speed I set the initial condition to in the physics sub section. Thanks! |
March 24, 2022, 08:00 |
Lucky
Rep Power: 66 |
If this is a steady simulation then you should get the same results regardless of initial conditions.
March 24, 2022, 08:04 |
#3 | |
Sam
Thanks for your help! |
March 25, 2022, 02:01 |
Lucky
Rep Power: 66 |
Perhaps the assignment is to run with different boundary conditions.
You can find boundary conditions in regions, find your boundaries, and check out the physics conditions and physics values. |
Strange results from boundary conditions. | SHAFKAT91 | FLUENT | 3 | April 18, 2017 13:42 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 17:19 |
Transient results with periodic boundary conditions? | holgerbre | Main CFD Forum | 4 | January 17, 2017 16:15 |
Running transient with steady results as initial conditions | cwl | STAR-CCM+ | 4 | November 29, 2016 09:31 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
