Importing a .msh file
Old   September 8, 2022, 07:04
Default Importing a .msh file
Bal
Bal
Bal is on a distinguished road
I'm trying to import a .msh file to star ccm. I've selected import volume mesh and then selected the the .msh file. it says import is complete, but i can't see the mesh. it's an empty scene. what do you suggest?
thnx
Bal is offline   Reply With Quote
Old   September 8, 2022, 14:20
Lucky
Create a new scene. Star has a rather quirky class system due to java references and a lot of times it's easier to just ignore the automation and create a clean scene. The Star equivalent of turning it off and on again.
Run the mesh check analysis. Verify the cell count is what you expect. Verify the range of x,y,z coordinates is also the range you expect. This way you know if you have a plotting problem or if you imported nothing.
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
