Marc Ricart
Rep Power: 3 ![]() |
I am trying to model the impact of the pressure increase in a "box" when a sudden burst of gas is released into it. The thing is that for outlet we will have a "valve" that will only allow flow out when internal pressure is above 100mbar. The thing is I don't know how to model that, If I use Pressure Outlet with a pressure of 100mbar the simulation goes crazy and diverges... Any idea how? shoud I use a porous media effect? Thanks |
Rep Power: 18 ![]() |
It's a unsteady case for sure. Would start with some simple 2D case and work on that.
Wave generation via field function and go for it. Some sinus stuff or with some excel table |
#3 | ||
Chaotic Water
Rep Power: 17 ![]() |
Marc Ricart
That what I had in mind... create a field function with 0 flow rate until 100mbar are achieved and then increase Mass flow out following the curve of the valve. The thing is that we don't know the curve but I'll try to find something or make something up
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
How to unserstand Correct boundary condition at outlet for incompressible flow? | aja1345 | FLUENT | 3 | July 16, 2018 12:12 |
Getting divergence while increasing the back pressure at pressure outlet | greenfields15 | FLUENT | 0 | March 18, 2018 23:39 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
