January 20, 2020, 01:01 |
Return code 36
Tom
Hi, I'm trying to reopen my previously saved simulation file, however a warning appeared saying:
Design STAR-CCM+ simulation completed Server process ended unexpectedly (return code 36) Cannot open file: C: desktop\user's folder\___.sim (specify - new to create the file) Server working directory:C:\documents does this mean the saved file has to be in a particular directory for it to work? Thanks in advance. |
January 27, 2020, 18:53 |
Rep Power: 24 |
No, it means the file you selected to open does not exist or the system doesn't have permission to read it.
March 25, 2021, 19:46 |
Return code 36
Alexander Perez
Rep Power: 5 |
I keep getting this problem when trying create a new file, old files I can open but it just doesn't let me create a new file. I was wondering if anyone knows a fix for this
March 26, 2021, 05:04 |
Chaotic Water
Rep Power: 17 |
Folder permissions, Read-Only probably?
March 29, 2021, 01:11 |
Matthias Fitl
Rep Power: 17 |
If the file does not exist you need to add
-new as option when you are calling starccm+, That's also stated in the erro message BTW starccm+ -server -new Hope it helps |
October 30, 2023, 18:19 |
Please Help!!
George Halliday
Rep Power: 2 |
I have this same issue on a simulation I just saved!
Where do you enter the -new to create the new one? If it is in the command section it is already in there sometimes and it doesn’t work. I have put -new in every part of the code and it doesn’t work so what can I do now as I really need to get this simulation back? Please if someone could help me I really appreciate it!! Thank you |
October 31, 2023, 04:09 |
Matthias Fitl
Rep Power: 17 |
Hello GeaorgeH25,
in the command line: starccm+ -new -server [-all_other_options_needed] You can get all options at the command line with starcmm+ --help Starting from the Client-GUI with File | New Matthias |
October 31, 2023, 05:51 |
George Halliday
Rep Power: 2 |
This is the issue I come across even adding the -new -server into the commands
October 31, 2023, 07:50 |
#9 |
Matthias Fitl
Rep Power: 17 |
If you issue -new ther must not be a file name in the call of starccm+. You need to connect to the server process with the client and save the file from the client.
Please make sure you can use OneDrive within starccm+ Please make sure there a no bad literals (like "'") in the filename or directory name |
error, return code, warning |
No matching function error: Phase change source term added to interMixingFoam | wavefunction | OpenFOAM Programming & Development | 2 | February 4, 2022 07:46 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
CFX-Post exiting with return code 4 | Andre Schlott | CFX | 3 | February 10, 2005 06:08 |
Help me, return code 255 | Valery | CFX | 1 | November 15, 2004 08:14 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
