Control Volume Analysis not adding up
Old   April 5, 2024, 07:30
Post Control Volume Analysis not adding up
Ludvig
ludvigum is on a distinguished road
Hello!
I am conducting a control volume analysis of a car simulation, but for some reason the forces don't add up.
My process: I have set up a force report with all the car parts (from regions) and set the vector direction in the drag direction. I set up a similar force report with just walls, ground, inlet and outlet boundaries from regions as well. Same was done for downforce, just in the downforce direction.
My problem: The drag force and downforce should equal the force reports of the domain in the same directions, but this is not the case. I get an error of approximately 10% for drag and 2% for downforce.
Does anyone have a clue why? I'm thinking it might be the mesh near the wall, but with some refined mesh I still don't get much lower errors.
This is for my master's thesis so it's important that the CV analysis is good for me to be able to trust the results.
ludvigum is offline   Reply With Quote
Old   April 5, 2024, 11:07
FliegenderZirkus is on a distinguished road
Are you sure that the same surfaces are selected in both of the force reports? It's hard to advise without seeing the simulation. BTW any reason why you're calling this a control volume analysis? If I get it right, you're just comparing two ways of selecting surfaces in a force report - either from parts or from regions.
FliegenderZirkus is offline   Reply With Quote
Old   April 5, 2024, 11:36
Ludvig
Thank you for replying!
I think my question was a little unclear. I am only using boundaries from regions, as this is where all data is located.
I am attempting to see if Newtons second law (sum of all forces in a direction equals zero) is achieved.
So I set one force report that reports the forces on the car, and then a separate force report where I input the domain boundaries which should provide an equal force in the opposite direction.
Hope that clarified what I am asking. I can’t show the simulation as it is confidential.
Old   April 5, 2024, 12:20
Ah ok, I understood the question differently.
So you're evaluating a force report on inlet and outlet boundaries. I'm not quite sure what that means to be honest. I've always evaluated forces on walls only. But that's not to say you're doing something wrong, let's just see if someone else replies.
Old   April 6, 2024, 00:56
f-w
f-w's Avatar
f-w is on a distinguished road
If your walls are not part of the free stream, then you can't group them with the inlet and outlet boundaries. That is, your boundary force balance should be: car + walls = inlet + outlet. Also, make sure your simulation is converged, and your force reports are configured to include forces due to pressure and shear (which should be the default).
f-w is offline   Reply With Quote
Old   April 6, 2024, 06:19
So this is a common thing to do? What would be the physical interpretation of a force evaluated on an inlet and outlet boundaries? Assuming the solver just integrates dot product of the user-supplied direction vector with (static pressure * face normal vector), you'd get something resembling the static pressure drop of the domain...? I'm guessing there's no shear contribution at inlet and outlet. Just thinking out loud here. I'm curious to hear from the experts.
Old   May 14, 2024, 11:57
Ludvig
That is exactly what I have done this far, and I still get an error of 10%. The simulation is converged and forces use Pressure+Shear (as default).
Old   May 14, 2024, 14:44
f-w
f-w's Avatar
If you say so, but your first post described it differently. You said you were comparing forces on [domain] to [car parts]. What I suggested is to compare forces on [domain, comprised of only inlet and outlet] to [everything else in your simulation]. If you are indeed doing this, then I can't think of any other solutions. As a sanity check, see if your inlet and outlet mass flows are equal in magnitude.
control volume, control volume analysis, cv analysis, drag
2 ways to mesh a multiRegion case - one works, the other fails boffin5 OpenFOAM Running, Solving & CFD 16 March 27, 2023 12:58
[snappyHexMesh] snappyHexMesh does not detect highly skewed faces? ptpacheco OpenFOAM Meshing & Mesh Conversion 1 January 4, 2022 12:37
multiphaseEulerFoam high Courant number Frenk_T OpenFOAM 5 November 24, 2016 03:23
Negative Volume during Mesh Motion Analysis giov_ingr FLUENT 2 December 13, 2013 06:09
