April 5, 2024, 03:17 |
Turbine in Star CCM+
Daniel Wirch
I'm a student and my thesis topic includes a CFD simulation of a radial turbine with Star CCM+. I am running a three dimensional implicit unsteady simulation with k-omega turbulence, coupled flow and ideal gas. The turbine should have a specific rotation rate as the goal, which i put into the simulation as a rigid body motion for the impeller region. How do I verfiy the design? Is it via the pressure drop between input and ouput? Is there another way?
April 5, 2024, 18:28 |
#2 | |
Peresvet
Rep Power: 5 |
https://youtu.be/xDyWPHa41KE |
April 9, 2024, 10:45 |
Daniel Wirch
Hello Peresvet,
thank you for the tip. I am going to implement the overset mesh for the impeller. What do you mean by the inverse problem? Have a monitor of the pressure difference between input and output? And what does "delov" mean? |
April 9, 2024, 14:11 |
#4 | |
Peresvet
Rep Power: 5 |
Delov! A proverb in Russian means, simply, easily, without problems. In my example, this is a wind generator turbine and it is spun by the air flow at the inlet. In your case, I assume, the turbine has already been given a rotation speed and all that remains is to determine the pressure. To control the pressure in a given section or on the surface of a turbine, etc., you need to create a new scalar scene and select the field function in it > select the appropriate one from the list. |
rigid body motion, turbine, verification |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 22:15 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
