Rep Power: 16 ![]() |
Hello all,
I was wondering if anyone out there has any experience will multi-stage turbomachinery simulations. I have attached a photo. As you can see, I'm trying to use a moving reference frame model to simulate motion in my rotor row. I'm planning on doing this by going to region->rotor->physics values - > moving reference frame -> and setting my value equal to omega *r, my desired speed. Is this an acceptable way to go about it? The big question I have concerns the fact that my spacings for the blade rows are different, so my two pieces that I import into Star-CCM+ aren't of the same "height" as you can see in the photo. For the areas that do overlap, (drawn in blue), I am planning on using both "in place" and "indirect mixing plane interfaces". However, I am not at all sure about what I should do about the regions drawn in red. I was really hoping someone out there could throw me some pointers. Also, if the approach I'm taking it completely wrong, please feel free to let me know. The biggest issue I'm having problems with is that my blade spacings are different, and thats def. making this more difficult than it otherwise would be. Thanks for any help, apc |
#2 | |
Rep Power: 17 ![]() |
Hi apc,
although I have no experience in modelling multi-stage turbomachinery with ccm+, I have been simulating compressors with Numeca and CFX. The beauty of the mixing-plane interface is that it was made exactly for this pupose/problem. If you provide the periodicity for the blade-rows you have a complete interface in between the two rows. This is what the circumferential averaging is for. So actually the red surfaces should be part of the blue surface as this should be one interface. They do not need to be a of the same perodicity. Though in heigth they should be the same. Sorry, I can not give you a more specific answer for this problem in CCM+. And I hope this is not too late anyway. Quote:
By the way, I am working on a similar problem in ccm+ right now. Trying to get a mixing-plane interface in ccm+ working. So far it is not working, but I have tried only with a indirect interface. Now I will try to make it the way you suggested it with an additional in-place interface. --mrjonezz |
Unanswered question | niklas | OpenFOAM | 2 | July 31, 2013 16:03 |
turbomachinery question | Marek | CFX | 0 | February 2, 2009 05:51 |
Question about multi domain | Rodrigo Basniak | CFX | 0 | April 1, 2008 09:35 |
Turbomachinery at OpenFOAM Workshop Milan 2008 | hani | OpenFOAM | 0 | March 21, 2008 02:33 |
question | K.L.Huang | Siemens | 1 | March 29, 2000 04:57 |
