Running macros in parallel in batch mode
Like Tree1Likes
  • 1 Post By MFitl
Old   April 20, 2010, 18:48
Default Running macros in parallel in batch mode
John
nomad is on a distinguished road
I'm trying to run a simulation with a macro, with 4 cores on a local machine, in batch mode using the following:
starccm+ -np 4 -batch file.sim file.java
and I get the following error:
Warning : CPU Timer not running
Warning : Wall Timer not running
Server Error: There are no regions to solve on
It works fine using a single core in serial mode (starccm+ -batch file.sim file.java).
Any help would be appreciated.
Thanks.
nomad is offline   Reply With Quote
Old   April 21, 2010, 12:03
Maddin is on a distinguished road
Start the server and then start the java file with "a client session".
I had the same problem... never found a other way.
Maddin is offline   Reply With Quote
Old   April 21, 2010, 13:48
John
I'm running starccm in an optimization loop. Starting it without batch mode requires me to end the starccm process after the max iteration has been reached in order for the optimization to proceed to the next run.
Is there an option to end the client and exit starccm?
Thanks.
Old   April 22, 2010, 02:56
Matthias Fitl
MFitl is on a distinguished road
Originally Posted by nomad View Post
You might want to try
starccm+ -np 4 -batch file.java -collab -load file.sim
This works on our Linux machine since V3.something
CU,
Matthias
Doggidog likes this.
MFitl is offline   Reply With Quote
Old   April 22, 2010, 13:14
John
Hi Matthias, that partly works. All the cores are now available for use (100% CPU usage), but only one core is being used most of the time.
Any ideas?
Thanks.
Old   April 22, 2010, 14:53
John
Just to shed light on what I've been seeing with the following:
I've attached an iteration time plot. The one on the left is with a single core, roughly 1.2sec/iteration, while the plot on the right is with the above option, running 4 cores, 0.4sec for the fastest iteration, and 28 sec for the slowest, with the entire parallel run taking longer than in the serial case.
Any ideas on why this cycling is happening, and a way to control it?
Thanks.
Old   April 22, 2010, 15:50
Vinicius Girardi
Vinicius is on a distinguished road
What are your hardware configuration, mesh size and mpi version?
Vinicius is offline   Reply With Quote
Old   April 22, 2010, 18:31
John
Hi Vinicius,
It's an i7-920 24G RAM, Windows XP64 SP2
mesh size 150,000 cells
MPICH2 v1.03.
Thanks.
Old   April 22, 2010, 21:27
Vinicius Girardi
Maybe you are using too many cores to this small mesh and the parallelization time is higher than the calculation. It's not a rule, but I usually add a core each 250 000 cells.
Old   April 23, 2010, 12:50
John
It seems like MPICH2 uses 1 extra process, so if I request 4 cores, it runs 5 processes and it has trouble distributing 5 processes over 4 cores. It runs well with 3 cores.
So the solution would be to use 1 core less than the total available.
Issue has been resolved.
Thanks to all who replied.
Old   April 29, 2010, 00:41
100.000 cells for each core, adapco said 70.000 cells core where enough.
But it's sometimes faster with collab?
Old   April 29, 2010, 05:00
Matthias Fitl
the -collab flag only enables other users to connect to the server process and therefore interact with it.
On Linux/Bash:
alias starccm+="$(which starccm+) -collab"
enables this feature constantly.
Regards,
Matthias
Old   April 29, 2010, 06:16
I know... but why this difference?
Old   February 22, 2013, 08:30
Edgar Flores
ericardofa is on a distinguished road
Hey nomad,
By any chance you can post .java macro you're using?
Thanks in advance
Regards
ericardofa is offline   Reply With Quote
batch, cpu timer, macros, parallel, wall timer
Parallel Fluent Error in Batch Mode Justin FLUENT 3 November 28, 2016 10:50
Running fluent with udf in batch mode zonexo Fluent UDF and Scheme Programming 2 March 10, 2012 07:50
DPM model in parallel batch mode Prashanth FLUENT 2 March 6, 2009 07:54
Running Job in Batch mode (EFD) Nick Sessions FloEFD, FloWorks & FloTHERM 0 April 16, 2008 16:44
problem with running UDF in batch mode James FLUENT 0 June 6, 2006 06:49
