K-Omega SST Turbulence Model
Old   July 19, 2010, 12:08
Default K-Omega SST Turbulence Model
nvtrieu is on a distinguished road
I'm doing simulation the flow over NACA0012 airfoil. In order to predict the lift/drag coefficient as long as the stall angle, the k-omega SST turbulence model is used.
The flow's specifications as follows:
-Velocity inlet: U=91.79 m/s
-Chord length: c=1 m
-Reynolds number: Re=6 million
-Fluid density: rho=1.2126 kg/m3
-Dynamic viscosity: muy=1.86x10^-5 Pa-s
Boundary conditions:
-Velocity inlet: inlet
-No-slip wall: foil
-Pressure outlet: outlet
When I selected the Turbulence specification is "k + omega" for Initial condition and for Inlet boundary condition, after running several iterations, I got this error:"Sever error: A floating point exception has occurred: floating point exception [overflow]. The specific cause cannot be identified. Potential causes may include: (a) solution divergence due to poor mesh quality, crude initialization, etc., or (b) errors in user-defined code or field functions."
This error also happened when I selected "Intensity + Length scale" for Initial condition.
Although, I used a very fine mesh with y+<1 (C-mesh). And I did not defined any field function.
However, when the Turbulence specification was turned into "Intensity + Viscosity ratio" for Initial condition, there was no error.
My first question is: Why I cannot change the Turbulence specification in Initial condition as I did?
The reason why I would select "k+omega" for Initial condition and for inlet boundary is I'm going to set the values of turbulent kinetic energy (k) and specific dissipation rate (omega).
Second: When the outlet boundary is set as Pressure outlet, do I need to change the Turbulence specification for outlet boundary into "k + Omega" as long as "Intensity + Length scale" or I just left it as "Intensity + Viscosity ratio"?
Thanks for any helps!
Trieu.
Email: trieuckgt@gmail.com
MSN: trieu.dut@live.com
YM: trieu_tme@yahoo.com
nvtrieu is offline   Reply With Quote
Old   July 21, 2010, 02:54
Maddin is on a distinguished road
Initial conditions? Velocity = 0? and inlet with 90+ m/s?
Drink some beer and think about that.
Maddin is offline   Reply With Quote
Old   July 21, 2010, 02:58
Hi Maddin,
Initial velocity=Inlet velocity.
I've solved for this problem.
Thanks!
Old   July 21, 2010, 05:05
Ok! What was the problem?
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
Huge Heat Transfer Coefficient with SST turbulence model andoss CFX 4 January 9, 2010 07:40
Understanding k-omega SST model source code tmhonka OpenFOAM Programming & Development 1 September 8, 2009 07:33
SST transitional turbulence model Ben Akih CFX 3 June 8, 2006 15:52
