Ammar
Rep Power: 14 ![]() |
I want to optimizie the air-flow in a room & im new to star ccm.
What should I do? Should I follow the simple flow tutorial? if yes, should I change the values & properties? |
Rep Power: 21 ![]() |
The tutorials are a good starting point.
You can play around with the parameters from the tutorials and have a look what happens. For the air flow in a room, you might have a look on gravity and ideal gas (for buoyancy effects) and maybe (depending on your problem) unsteady simulations. A lot of properties contain "expert properties". You should not twiddle with them unless you know what you are doing. |
CFD for air flow analysis in a room | bidalufias | Main CFD Forum | 1 | May 12, 2011 19:11 |
Simulation of air flow inside valve - FSI? Help! | farianka | Main CFD Forum | 0 | April 17, 2011 16:30 |
air flow simulation in double skin facade with openfoam | gygfei | OpenFOAM | 1 | December 20, 2010 04:50 |
Air flow question | Bruce | Main CFD Forum | 2 | February 21, 2009 04:52 |
HELP!!! Indoor air flow pattern | Peter Zhang | Main CFD Forum | 4 | November 3, 1999 02:49 |
