Linux Batch - Star-CCM+ .. running Sims in batchmode
Old   August 16, 2011, 04:20
Default Linux Batch - Star-CCM+ .. running Sims in batchmode
eRzBeNgEl is on a distinguished road
Hi guys
I know how to run Star-CCM+ in batchmode in Windows with following code:
"C:\Program Files\CD-adapco\STAR-CCM+5.06.007\starccmw.exe" -batch -np 4 -report G1_32.sim
I know how to set up a batch file in Linux and make it executeable. Does ist work the same way like in Windows?
Add Info:
it should work that way:
start Simulation G1 -> run until Iteration Step 1000 -> Save the File under G1.sim
start Simulation G2 -> run until Iteration Step 1000 -> Save the File under G2.sim
and so on.....
eRzBeNgEl is offline   Reply With Quote
Old   August 18, 2011, 05:00
Hi guys,
ok, no i have my skript and i can start the simulations in a folder. But there is another problem right now. While loading the Simulations in Bashmode it stops always at the same line and do not start running the simulation. Where is the problem?
Here is the log File:
Starting STAR-CCM+ parallel server
HP-MPI licensed for CD-adapco.
Host 0 -- ip 192.168.208.1 -- ranks 0
Host 1 -- ip 192.168.208.1 -- ranks 1 - 2
Host 2 -- ip 192.168.208.2 -- ranks 3 - 6
Host 3 -- ip 192.168.208.3 -- ranks 7 - 10
Host 4 -- ip 192.168.208.4 -- ranks 11 - 14
host | 0 1 2 3 4
0 : SHM SHM TCP TCP TCP
1 : SHM SHM TCP TCP TCP
2 : TCP TCP SHM TCP TCP
3 : TCP TCP TCP SHM TCP
4 : TCP TCP TCP TCP SHM
Prot - All Intra-node communication is: SHM
Prot - All Inter-node communication is: TCP
MPI Distribution : HP MPI-2.03.01.00
Process rank 0 clst516-1 2681
Process rank 1 clst516-1 2683
Process rank 2 clst516-1 2682
Process rank 3 clst516-2 2563
Process rank 4 clst516-2 2592
Process rank 5 clst516-2 2596
Process rank 6 clst516-2 2591
Process rank 7 clst516-3 2708
Process rank 8 clst516-3 2700
Process rank 9 clst516-3 2690
Process rank 10 clst516-3 2687
Process rank 11 clst516-4 27115
Process rank 12 clst516-4 27110
Process rank 13 clst516-4 27090
Process rank 14 clst516-4 27114
STAR-CCM+ Version 5.06.007 (linux-x86_64-2.3.4/gnu4.4)
License version: 23 Oct 2009
Required feature version set to 2010.10 or later
Checking license file: 1999@192.168.208.20
Checking license file: 7241
Unable to list features for license file 7241.
Checking license file: clst516-1
Unable to list features for license file clst516-1.
Checking license file: 1999@516_fez
Unable to list features for license file 1999@516_fez.
1 copies of ccmpsuite checked out from 1999@192.168.208.20
Feature ccmpsuite expires in 13 days
Loading file: /home/fem/daten2/test/test1.sim
Loading simulation database: /home/fem/daten2/test/test1.sim
Loading module: StarMeshing
Loading module: MeshingSurfaceRepair
Loading module: MeshingPipeline
Loading module: StarResurfacer
Loading module: StarDualMesher
Loading module: MetricsModel
Loading module: MotionModel
Loading module: MaterialModel
Loading module: SegregatedFlowModel
Loading module: KeTurbModel
Loading module: StarDelaunayMesher
Database saved by:
STAR-CCM+ Version 5.06.007 (linux-x86_64-2.3.4/gnu4.4) Np=15
Tag date = 2010-09-30 19:49:14 GMT
Loading into:
Simulation database load completed.
Finished loading file
Server::start -host clst516-1:47827
!!!!!!!AND HERE IT STOPS::::::WHY?????!!!!!!
Old   August 27, 2011, 05:05
abdul099 is on a distinguished road
Can you post the command you've used to start the simulation? (Complete line please)
abdul099 is offline   Reply With Quote
Old   August 29, 2011, 04:43
problem is already solved. U have to run the bash script without "$load" in the ccm+ command line....
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
A genearl question on STAR CCM nstar STAR-CCM+ 5 June 24, 2009 09:39
Running Fluent on Red Hat Linux WS version 4 Bob FLUENT 1 September 4, 2005 05:01
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Running Star From Command Line in HPC A.S. Siemens 4 May 19, 2005 08:28
