Model change: k-epsilon to k-omega SST results in divergence |
Rep Power: 0 ![]() |
Hey there,
At first, I am still a beginner in CFD with StarCCM+. ![]() I have a simulation of a stirred tank reactor. Using the k-epsilon-model works fine and the solution converges. Now I want to run the same simulation with k-omega SST, but the solution doesn't converge. I didn't change any default values. Do you have any general advices for me to achieve convergency? Thank you and best wishes, kw |
Rep Power: 18 ![]() |
Did it diverge or is it just oscillating? If your flow has unsteady features, they will show up more readily with K-omega than K-epsilon, even on a steady state simulation. K-epsilon is more diffusive, so it has a tendency to stamp out these oscillations.
At first it looked like that it wanted to diverge. I reduced the under-relaxation factors of Segrgated Flow, which helped. Now especially the Sdr-Plot is oscillating between 1e-4 and 1e-5 (no normilization).
k-omega SST simulation of turbulent flow around a circular cylinder | DanM | OpenFOAM Running, Solving & CFD | 17 | October 13, 2016 13:29 |
expert parameters of SST model? | David | CFX | 1 | December 2, 2005 06:36 |
SST model with rough wall? | David | CFX | 4 | November 30, 2005 11:22 |
SST model Autometic wall function parameters? | David | CFX | 0 | November 24, 2005 04:47 |
about Y+ in SST model | zuozicheng | CFX | 2 | July 12, 2005 10:05 |
