Mesh sensitivity when using phase change models
Old   February 28, 2012, 20:51
Question Mesh sensitivity when using phase change models
Brenton King
BKaus is on a distinguished road
I am having problems with the variation of solidification rate when solving different mesh sizes while using the Eularian multiphase VOF model with enthalpy-melting-solidification models enabled in CCM+.
I am solving the simplest model I could make (a 10x10x10mm cube) and using adiabatic surfaces on all boundary conditions bar two. The two faces that aren't adiabatic are set at different temperatures causing a delta T across the phase change material to induce melting. I am solving in unsteady state because I want to measure the rate at which the cube will melt.
The mesh size is causing large variances in the rate at which the cube melts. A finer mesh will cause the cube to react slowly and melting takes a long time. Where as a coarser mesh will cause the cube to react faster and melt quickly. I varied the mesh from 16 cells to around 37 million cells and I haven't been able to reach convergence on my mesh sensitivity test simply because I ran out of memory (96GB!) due to fact that the finest mesh I can create is too fine (100 million cells). Has anyone experienced such a large sensitivity in mesh size before?
Feel free to ask any questions you need to.
BKaus is offline   Reply With Quote
cd-adapco, melting, mesh, phase change, sensitivity
Thermal phase change model Piti CFX 1 January 14, 2021 10:03
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
Change parameters for Hybrid mesh karananand ANSYS Meshing & Geometry 3 July 18, 2010 16:37
Solid/liquid phase change using large viscosity gregor.vidmar153 OpenFOAM Running, Solving & CFD 3 June 10, 2010 06:31
thermal phase change question CFDflying CFX 1 February 18, 2004 04:10
