March 3, 2012, 09:57 |
Preventing backflow from occuring
BButler
Rep Power: 14 |
Im am working on a horizontal pipe resembling part of the lungs bronchioles. Instead of working with a pressure difference (between the inlet and outlet) I am focusing on volumetric flow rates therefore I am using a velocity inlet and a flow split outlet.
I am entering velocities using a time table as it is time dependent, air is entering the tube at a certain velocity for a certain time period. Then when the time is reached the velocity drops to 0 m/s and air no longer enters the tube. The problem is that when the velocity drops to zero m/s the air starts to flow backwards, this does not occur in the body. Is there anyway of entering a function or table to ensure the air flows out the tube once the velocity drops to 0m/s I want to work like an on/off switch Any help would be greatly appreciated |
March 3, 2012, 10:19 |
Thomas Ziegenhein
Rep Power: 14 |
you don't give the pressure difference at the pressure outlet, the pressure is depending on the wall shear stress (in a pipe). So use pressure outlet and you don't have problems with backflow. Because of continuity i think you can not deactivate the backflow.
Greetings Thomas |
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) | Josh | CFX | 9 | August 18, 2009 11:31 |
backflow temperature specification | jonglee | FLUENT | 0 | April 20, 2007 04:57 |
Problem with integrals and averages if backflow?? | Amit | FLUENT | 0 | October 19, 2006 18:54 |
Backflow occuring at a pressure outlet? | Dave | FLUENT | 1 | August 12, 2004 17:39 |
Swirl in backflow on pressure outlets | Jonas Larsson | FLUENT | 17 | February 3, 2000 02:14 |
