September 18, 2014, 04:49 |
unable to perform vset,newset,zone command
Ived
Rep Power: 12 |
Hi.. I am adding new piston crown cells to my existing geometry. But the new piston crown is placed very close to existing geometry and when I use command vset,newset,zone and then cset,newset,vset,any and then cset,save,12 along with piston cells, cylinder cells are also getting selected. I only want to make a set of new piston cells alone to perform some transform commands later.
I tried cset,delete,type,cursor to hide cylinder cells and select piston cells but it is not working as every time some cylinder cells are getting selected along with piston. Is there any way I can get my piston cells very far from existing geometry to ease my work? This might be a basic problem but I am not familiar with commands. Please help me out. Thank you. |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 11:37 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 04:41 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
