User codding -Scalar source-dynamic contact angle |
October 15, 2015, 05:06 |
iman
Rep Power: 10 |
Dear all, I am dealing with a problem in Star-CD, about the impact of droplet on a surface.
Scalar (1) =Air Scalar (2) =Water Indeed, I am going to provide dynamic contact angle (direct: Thermophysical model and properties—Multifluid—Surface tension— User) and phase source as a user coding (direct: Thermophysical model and properties—Source Terms—Scalar— User coding). Before doing these two step I also defined the fluid initialization (user coding) and Momentum source (user coding). For dynamic contact angle: defining these two equations is necessary Contact line velocity = -1* (vector (velocity) *grad (volume fraction water)) Capillary number = (Contact line velocity*Dynamic viscosity) / surface tension force And for Source Scalar: 1- Knowing the value of VOFwater (scalar (2)) at each time step (so, should be exported the data at first) 2- Then, comparing of these (VOFwater) at two time step I would be appreciated if anyone could help me to that what kind of function as user coding (as like, defining the vector, Gradient, export, import, working example …) would be suitable in this condition. Thank you very much in advance. |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
dynamic contact angle udf returns no value to solver | shiraz_man67 | Fluent UDF and Scheme Programming | 5 | July 3, 2018 14:51 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
