Home > Forums > Software User Forums > Siemens > STAR-CD
Comparing of Scalar value at each Time step -Subroutine
Old   October 28, 2015, 02:17
Default Comparing of Scalar value at each Time step -Subroutine
IRP
iman
IRP is on a distinguished road
Dear all, I am dealing with a problem with Star-CD, about the impact of droplet on a surface.
Scalar (1) =Air
Scalar (2) =Water
Indeed, I am going to compare of Scalar (2) at each time step and put the bigger value instead of the lower one.
i have a difficulty to set these kind of subroutine.
Phase source as a user coding (direct: Thermophysical model and properties—Source Terms—Scalar— User coding).
I would be appreciated if anyone could help me to that what kind of function as user coding would be suitable in this condition.
Thank you very much in advance.
IRP is offline   Reply With Quote
Old   October 30, 2015, 06:25
Blanco
Blanco is on a distinguished road
I don't know if I properly understand your problem...but if you want to set the value of a scalar somewhere in your simulation domain, as the value you get during your simulation somewhere else at each time-step, then you should use both posdat.f and the user coding for the scalar source terms.
You can post-process the scalar value at each time step using posdat, then create a variable to be shared with scalar source term subroutine and use that variable in the source subroutine to set what you need.
Hope this helps,
Regards,
Andrea
Blanco is offline   Reply With Quote
Old   October 31, 2015, 22:13
IRP
iman
Dear Bianco
Thanks a lot for the reply. Actually, I have read the manual, but I still have problems regarding this implementation (to write a subroutine using posdat.f). Could you be so kind and point me to some references or samples, in order to understand how to apply it.
Indeed, I want to consider the wetting condition of wall boundary. A solid surface has its own absorption characteristics. For example, glass and metal surfaces do not absorb the liquid, but a paper surface does. This different property makes different traces when the liquid moves on the solid surface. As I mentioned in the opening, I am going to provide the scalar source in which whenever the surface becomes wet, permanently it stays wet by comparison of the scalar value at each time step, and adding the amount of decreasing during the spreading.
Old   November 9, 2015, 03:21
Blanco
I think it's not very easy to implement what you want, but in any case the very first step is writing a posdat in order to obtain the scalar value on the wall, in order to track it. I would suggest to contact your local sales dept. in order to ask assistance about the posdat, because there are lot of variables available other then the ones writtne in nom.inc.
I suppose you have already tried a simple wall liquid film model, am I right?
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
