Home > Forums > Software User Forums > Siemens > STAR-CD
downwardly compatible
Old   March 26, 2009, 10:52
Default downwardly compatible
Luke is on a distinguished road
Hello everybody.
Does anybody know, whether Star is downwardly compatible.
Because at the moment we use Star CD V4.06 and when we want to open a .mdl file generated with Version 3.26 we achieve the message:
**WARNING - FILE param.prp IS INCORRECT. IT COULD BE FOR A DIFFERENT VERSION OF pro-STAR. A NEW param.prp WILL BE WRITTEN AUTOMATICALLY
BASED ON THE .mdl FILE BEING OPENED.
**ERROR - NOT ENOUGH MEMORY CAN BE ALLOCATED. USE A SMALLER PARAM.PRP FILE OR A LARGER MACHINE.
But the size of file param.prp is only 3kB.
Thank you in advance
mfg Luke
Luke is offline   Reply With Quote
Old   March 26, 2009, 11:16
Anton Lyaskin
A_Lyaskin is on a distinguished road
First, try to delete param.prp file at all - ProSTAR will create a new one with default parameter values on opening then model and then try to adjust their values. Even if it fails, chances are that you'll get a more specific error message in this case, telling you what parameters shoukd be increased.
A_Lyaskin is offline   Reply With Quote
Old   March 26, 2009, 11:23
Hello A_Lyaskin.
Thanks a lot. This was exactly the information we needed. Now we can run the file. Have a nice day.
mfg Luke
Old   July 27, 2010, 02:13
tombur
tombur is on a distinguished road
hellow everyone..
i have a question with the way and steps for install star cd and ccm in windows 7 (x86 or install in x64). I ussually have a problem in running program. What star cd v4.08 is compatible for windows 7 ?
thank you for your information
tombur is offline   Reply With Quote
Old   July 27, 2010, 07:39
Robert
RobertB is on a distinguished road
Not sure about 4.08 but I have 4.12 running fine on Windows 7 64.
CCM+ 5.04 installs as well, for some earlier versions I think you have to turn on Vista compatibility.
For both I was using the windows 64 bit version.
RobertB is offline   Reply With Quote
Is Ansys compatible with Window Vista? If yes then NITIN DEWANGAN CFX 2 July 13, 2008 18:18
compatible linux and Starcd zhihua Siemens 1 March 14, 2008 08:21
Files Compatible with GAMBIT David Banks Main CFD Forum 0 July 10, 2007 09:15
AMD X2 & INTEL core 2 are compatible for parallel? nikolas FLUENT 0 October 5, 2006 06:49
Solidification X Compatible Phoenics Version Henrique Argentieri Phoenics 2 December 6, 2002 13:02
