Home > Forums > Software User Forums > Siemens > STAR-CD
velocity-dependent diffusivity
Old   August 17, 2009, 15:01
Default velocity-dependent diffusivity
Mark Porter
porterma is on a distinguished road
I am using star-cd (version 4.06). I need to define a velocity-dependent diffusivity coefficient for a passive scalar. I have worked out that I need to write a subroutine using pordif.f. What I can't figure out is how I access the magnitude of the velocity that has already been calculated by star-cd. My calculation is very simple:
PORODF = 0.0522*v + 1e-8
where v is the velocity magnitude at every location in my volume. It seems like should be very easy, but I can not find any documentation regarding this matter.
Thanks in advance.
porterma is offline   Reply With Quote
Old   August 17, 2009, 19:58
Pauli
Pauli is on a distinguished road
At the top of pordif.f you should have this line:
INCLUDE 'usrdat.inc'
It will provide U,V,W in global cys. See nom.inc for details.
usrdat.inc & nom.inc will appear in your ufile directory when you compile (star -ufile).
Pauli is offline   Reply With Quote
Old   November 5, 2009, 13:18
Default direction-dependent difusivity
Mark Porter
Thank you for the reply Pauli. I know this is very late, but we had some license issues here and I haven't been able to use star-cd in awhile. Thus, I now return to my problem. I implemented the velocity-dependent diffusivity for each region in my model domain as follows:
IF(NPPOR.EQ.1) THEN
  PORODF = 0.00152*SQRT(UL**2 + VL**2 + WL**2) + 3.6431E-10
ENDIF
I have one question regarding this implementation. I wasn't sure if UL, VL and WL are the appropriate velocity components or if I should be using U, V and W. In porous media flows, there is a superficial velocity and a pore velocity; they are related by the porosity (i.e., pore velocity equals the superficial velocity divided by the porosity). Based on the description of each I could not determine if if U or UL was the pore velocity. Does anyone know which is which.
My other concern is that in porous media flow the diffusivity becomes a tensor (similar the alpha and beta tensors that are implemented in star-cd). But the diffusivity is treated as a scalar. In the code above I technically need a PORODF for each component (x,y,z) of flow. It appears that I need additional if statements that identify each component of flow. For example, the if statements should look something like this:
IF(???.EQ.1.AND.NPPOR.EQ.1) THEN
  PORODF = 0.00152*UL + 3.6431E-10
ENDIF
IF(???.EQ.2.AND.NPPOR.EQ.1) THEN
  PORODF = 0.00152*VL/10 + 3.6431E-10
ENDIF
IF(???.EQ.3.AND.NPPOR.EQ.1) THEN
   PORODF = 0.00152*WL/10 + 3.6431E-10
ENDIF
The problem here is that I can't find the variable (the ??? in the above pseudo code) used to identify each component of flow?
Thanks in advance.
porter
Old   November 5, 2009, 14:03
Pauli
U is velocity in the global CSYS. UL is the velocity in the porous media CSYS. I don't know if it is superficial or otherwise.
It looks like diffusivity is implemented as isotropic (i.e. a scalar). I have no idea how you can make it otherwise. I don't think your psuedo-code would work.
Both are good questions for CD-adapco support.
time dependent velocity input by user subroutine shohel mahmud Siemens 4 December 18, 2007 11:40
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
A velocity dependent kepsilon boundary condition tangd OpenFOAM Pre-Processing 2 September 15, 2006 07:04
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
