Home > Forums > Software User Forums > Siemens > STAR-CD
Scalar polynomial for specific heat is not defined!
Old   September 20, 2009, 21:55
Angry Scalar polynomial for specific heat is not defined!
navid
navid is on a distinguished road
My case is about investigating injection and combustion of a diesel fuel (n-dodecane) in a chamber. Actually prostar dose not let me save the specific heat as a polynomial function for AIR . I select N2 specification for air.
When I click apply, a message appear in the command output window which says,
'YOU MUST USE THE POPCP COMMAND TO DEFINE THE COEFFICIENTS OF THE POLYNOMIAL.
IF SCALAR DATA IS PRESENT, YOU MUST USE THE POSCP COMMAND TO DEFINE THE SCALAR COEFFICIENTS'.
when I try to save the problem an error appears on the screen which says "Scalar polynomial for specific heat is not defined"! just when I select a constant specific heat for air, software let me write the problem
How should I define spesific heat for air as a a polynomial in my problem using POPCP or POSCP orv other commands?
navid is offline   Reply With Quote
Old   April 16, 2010, 06:00
Question same problem
Heintz Simon
sheintz is on a distinguished road
Send a message via MSN to sheintz Send a message via Skype™ to sheintz
Hello
Have you found a solution to this problem ?
I have actualy the same problem.
Thank you in advance
Best regards
sheintz is offline   Reply With Quote
Old   April 19, 2010, 05:00
Default the solution
Heintz Simon
hello navid,
i have found the solution of our problem :
we have parameterd polynomial model for the viscosity, the specefic heat and the conductivity of the air, who is a gas and the boundary condition. Also now we have to specify the FuelGas properties too in polynomial model in the panel Thermo Mod and Prop > Additional Scalars > Moleculars Prop !
Have fun
Best Regards
Simon
polynomial, popcp, poscp, specific heat, star cd
UDF to modify the value of a user defined scalar Raja Banerjee Fluent UDF and Scheme Programming 5 March 5, 2019 14:19
User defined scalar boundary condition Philip FLUENT 1 December 4, 2013 10:23
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
need help for using user defined heat exchanger sinha FLUENT 2 August 6, 2007 17:16
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
