June 16, 2010, 01:43 |
StarCD 3.26 & 4 Importable File Types
Rep Power: 15 |
Hi all,
I was curious as to whether anyone has a list of importable file types for each of the different versions. Specifically I was hopping to import .ccm file into StarCD 3.26. But I have yet been able to find out how to do it. Any help would be greatly appreciated. Regards T |
June 16, 2010, 02:15 |
#2 | |
Mark Olesen
Rep Power: 40 |
June 16, 2010, 02:19 |
Rep Power: 15 |
Cool
I just tried out StarCD v4.12 today and it worked. .ccm files can be imported by StarCd v4.12. Now here is another challenge for those of you out there. Is it possible to convert a StarCD v4.12 .mdl file to one thats usable in StarCD v3.26? I initially thought that it was possible. But I keep getting errors. This could however be becaues of the fact that I imported the .ccm file in v4.12. But im not too sure. I really do appreciate the help! Thanks in advance T Last edited by trex930; June 16, 2010 at 04:48. |
June 16, 2010, 07:24 |
Robert
Rep Power: 16 |
Yes, generate a prismatic/tet mesh in CCM+.
Remember to set the option in the prism mesh model to generate tets/prism only. Write out a ccm and read back into Star 4. Write out ASCII cell and vertex files CD/adapco have a short Fortran program that will convert the files to STAR 3 format (they should give it to you if you ask). If you get errors you have Polys in the CCM+ (despite having asked for none). The usual error is that the boundary layer is too thick and the code collapses the prism layer, generating polys. Try a thinner boundary mesh layer. You should then be able to suck the model into STAR 3.26. You might want to use the command TETAlign after import to optimize the tes for STAR 3.26. |
June 16, 2010, 19:41 |
Rep Power: 15 |
Hey Rob,
Thanks for the reply. I'll give it a shot today and keep you posted! When you say prismatic/Tet. You're talking about prism layers, as well as a tetrahedral mesh right? Is it not possible to do it with a trimmer mesh? Because ideally that's what we would like to use. Thanks in advance! T Last edited by trex930; June 16, 2010 at 20:20. |
June 17, 2010, 02:36 |
#6 | |
Mark Olesen
Rep Power: 40 |
You thus may or may not need to rescale your vertices accordingly. You can only do this indirectly. Save the model as coded and read that it in the older version. With some luck it will understand most of the commands and ignore the unknown ones. Of course you need to make sure that the cread/vread within this .inp file use the correct v3-compatible format. |
June 17, 2010, 03:54 |
#7 | |
Rep Power: 15 |
Hey again!
Thanks for your input! Just have a quick question for you! Quote:
Cheers, T |
June 17, 2010, 04:46 |
Oliver Lauer
Rep Power: 17 |
The real problem between 4.x and 3.26 is that in 3.26 only some very special polyhedral cells (called trim cells) are allowed. I do not think that it is possible to configure 4.x or CCM+ in a way to create trim meshes which can be read back to 3.26. The created polyhedral cells (even in trimmed meshes) are not backward compatible to 3.26 trim cell definitions.
The only thing I could imagine is - as already said - tets and prisms. |
June 17, 2010, 08:35 |
#9 | |
Mark Olesen
Rep Power: 40 |
I believe they still work okay, but haven't used them for quite some time. See the '-h' option for the usage. /mark |
June 17, 2010, 20:16 |
#10 | |
Rep Power: 15 |
T |
June 18, 2010, 11:01 |
#11 |
Rep Power: 17 |
Instead of jumping through so many hoops to force things that were never meant to work together, why don't you just use STAR4? What is the big deal about forcing everything back to STAR3? STAR4 was built to use general polyhedra and is fully compatible with anything you can generate in a .ccm file. You obviously have STAR4 so why are making so much work for yourself?
June 18, 2010, 19:10 |
#12 |
Robert
Rep Power: 16 |
Have you actually used STAR 4 for real sized problems, 10 - 20 million cells? The plotting is so slow as to make it practically unusable.
If you like and use Prostar use 3.26. If you like CCM+ and Polys use it. Star 4, with the best will in the world, neither has the toolbox benefits of 3.26 nor the just 'leave it to me' benefits (?) of CCM+. I use both and have not, to date, found a compelling area where Star 4 is the answer. There may be some area of physics in which it is compelling but I do not need that benefit. |
June 19, 2010, 05:55 |
#13 |
Rep Power: 15 |
Hey!
Thanks for you input guys! @TMG: I understand what you mean. I have star 4, but the Engineer that needs the files that Im working on only has star3.26! Thats why im going through all this work! haha may I also ask Mark: I have managed to extract the files from the link you posted. (Thank You very much by the way). But Im having trouble running it. Linux recognizes that its an executable, but when i type in the name (eg. star-backport) it says unknown command. Im fairly new to Linux, so any hints and tips would be super beneficial! T Last edited by trex930; June 20, 2010 at 22:17. |
June 21, 2010, 02:19 |
#14 | |
Mark Olesen
Rep Power: 40 |
eg, Code:
/some/path/to/program/star-backport OR ./star-backport (if it is located in the current working directory) |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
gcc and executable file from Mac to Linux | simone Marras | Main CFD Forum | 0 | April 8, 2007 15:49 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
