Home > Forums > Software User Forums > Siemens > STAR-CD
Setting up a porous media
Old   June 25, 2010, 04:29
Default Setting up a porous media
Nicholas
en51nm is on a distinguished road
Hi all,
I've been having some trouble setting up a porous media flow in Star-CD v4 through a porous baffle. I know the force ({F_p}) and hence the pressure drop across the baffle and I need to calculate {\alpha} and {\beta}:
{\Delta p = - \rho ( \alpha \upsilon + \beta ) \upsilon}
where {\upsilon} is superficial velocity and {\rho} is fluid density (I assume).
I seem to have too many unknowns, since I do not know the superficial velocity... any ideas would be greatly appreciated.
en51nm is offline   Reply With Quote
Old   June 25, 2010, 08:15
Oliver Lauer
olauer is on a distinguished road
But you know pressure drop for a given mass flow. And you now the area of your porous baffle, and the density. So you can calculate a mean velocity. Better would be to have pressure drops for more than one mass flow because you have two unknowns
olauer is offline   Reply With Quote
Old   June 25, 2010, 10:32
Pauli
Pauli is on a distinguished road
You have one equation with two unknowns. You need the force/pressure drop at two or more flow rates. Then you can curve fit the equation to the data.
Pauli is offline   Reply With Quote
Old   June 25, 2010, 10:42
Nicholas
I have one force value, but I don't have an associated flow rate for that force. How can I calculate the flow rate in the porous media?
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
species mass source in porous media ? PK FLUENT 0 February 16, 2007 11:12
Testing the integrity of POROUS media and por jump Azman FLUENT 0 July 31, 2006 11:11
Warning 097- AB Siemens 6 November 15, 2004 04:41
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
