November 25, 2016, 13:21 |
Calculate stresses given displacement in 3D
Rep Power: 11 |
Thanks in advanced for reading my query and taking the time to respond. I have two 3-D objects. The first is in an undeformed state and the second has has undergone deformation by applying a force on the bottom and on the side (red arrows). - I know the material properties. Assume it is perfectly elastic. - The object is fixed in at one point (the top, green) Is it possible to calculate the stresses required to deform this shape form state 1 to 2 given the change in shape and physical properties? If so, what is a strategy for doing this? Can this be done within ANSYS workbench? Thanks again. |
November 27, 2016, 10:02 |
Alex
Rep Power: 47 |
Sounds like this could be done with a static structural analysis. Use displacement boundary conditions instead of forces.
Among other results, you get the forces necessary for the deformation and the stresses inside the object. |
November 28, 2016, 13:41 |
#3 | |
Rep Power: 11 |
To use the displacement boundary conditions, I assume I would need to identify landmarks on both the 3D models and calculate the displacement of those landmarks. Do you know of a method where this could be done (semi-) automatically? Thank you once again. |
December 1, 2016, 14:03 |
#4 | |
Rep Power: 11 |
calculate velocity difference | helly | OpenFOAM Post-Processing | 0 | June 21, 2016 08:49 |
Momentum and displacement thickness: du/dy calculation | Josh | CFX | 13 | October 27, 2013 14:38 |
calculate values for eps and k from Re or u????? | sbar | OpenFOAM Pre-Processing | 5 | August 16, 2010 04:10 |
How to calculate Torque for francis turbine | manish | CFX | 4 | March 15, 2007 02:57 |
Calculating principle stresses (Difficult) | Joe | CFX | 5 | March 7, 2007 11:55 |
