July 21, 2017, 16:00 |
Create line-to-line contact
Rep Power: 9 |
Hi.
I want to model contact between steel cables. To generate the cables I'm creating lines and then asigning them a circular cross section in the Design Modeller, which works fine. The main problem is when I try to define contact pairs for the wires in the cable. I'm quite certain that one can create a contact surface for a line/edge object, defining a radius for the position of the surface around the line. The problem in that Mechanical won't accept my Contact and Target inputs as the lines which define each strand. Is there a way that I could define this contacts through WB or maybe via a command line? Cheers Last edited by ISV; July 27, 2017 at 19:11. |
July 25, 2017, 01:55 |
Stuart
Rep Power: 25 |
I don't use Line Bodies myself, but if you cannot use a Contact could you instead put them in a Multi Body Part in DesignModeler, they will share the end node and not require a Contact.
July 27, 2017, 19:10 |
Rep Power: 9 |
I don't think that would work since I need to define a Frictional contact between the beams.
July 28, 2017, 06:30 |
Stuart
Rep Power: 25 |
Sorry, I should have read your question properly. You are talking about the frictional contact between adjacent wires in the cable, this can be quite a complex interaction depending upon the loads. Is this for a static or transient FEA? What are your boundary conditions? You may have to use the explicit dynamics solver in Mechanical Enterprise (used to be called Explicit STR before Release 18.0), assuming you have the appropriate licence. There you can use body interactions; either frictional or frictionless. Explicit dynamics often has to be used for complex interaction simulations and can be set up for quasi-static cases.
July 28, 2017, 12:26 |
#5 | |
Rep Power: 9 |
This are helical steel cables, composed of helical wires: 1 straight core (aka first layer), 6 helical on the second layer and 12 in the third layer. I'm fixating the cables in one end and imposing an axial displacement in the other end (all this aplied to the faces of the cross-section). I'll try using Explicit Dynamic. Thanks for the reply. |
[OpenFOAM] Take derivative of mean velocity in paraFoam | hiuluom | ParaView | 13 | April 26, 2016 06:44 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger | benru | OpenFOAM Meshing & Mesh Conversion | 3 | June 29, 2008 21:24 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
