LS-DYNA: End-of-file Error using *USER_LOADING_SET |
November 12, 2021, 06:24 |
Erik Scheurer
I'm new to ls-dyna and simulation as a whole and am getting an error where I don't understand whats wrong. In my dummy simulation I'm only doing a themal analysis of a simple cube and I'm trying to apply a user load through the keyword: *USER_LOADING_SET in the .k input file: Code:
*USER_LOADING 1.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 *USER_LOADING_SET 1TEMPTN 1 0 0.0 0.0 0.0 0 *** Error 20680 (STR+680) unexpected end-of-file This is only the case when USER_LOADING_SET is used and not for only USER_LOADING but I need both. I know I need to modify the code in dyn21.f of the ls-dyna code and I did but it doesn't reach the function loadsetud where I put my code. It seems to me that there is a keyword missing that is not named in the manual? If I use the option FORCEN instead of TEMPTN and do a stress analysis, it calls the load function as expected. The keyword check in LS-PrePost has no errors and these are the control keywords for the TEMPTN case: Code:
*CONTROL_SOLUTION 1 0 0 100 0 1 *CONTROL_TERMINATION 1.0 0 0.0 0.01.000000E8 0 *CONTROL_THERMAL_SOLVER 1 0 111.00000E-4 8 1.0 1.0 0.0 0 5001.0000E-101.00000E-4 1.0 1.0 0 0.0 0 *CONTROL_THERMAL_TIMESTEP 1 0.5 0.011.00000E-4 0.1 1.0 0.5 0 The cube is attatched in a zip. Thank you for taking a look! |
heat transfer, ls-dyna, thermal analysis, user-defined function |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
